Results 1 to 10 of 41
Thread: Leak in basement ,
    Dec 2019
    Brodheadsville
    251
    Wow! What a project. I went through the same thing with water leaking as I mentioned earlier. I was lucky not having to replace plywood, catching my leak in time. So, I assume the leak was from the roof. Man, that must have been leaking for a long time. Everything is looking good what you have done. Pex tubing. Perfect but takes all the fun out of plumbing!
    1995 Liberty XL
    Chris & Sara Jo Behrens
    Mar 2024
    Muncy
    69
    Yes I say they took the plumb out of plumbing with the pex pipe now it’s just ing ! So now you’re an inger not a plumber! We’re finishing the closet for the water now just some new led lights to do yet I’ll try to post a pic? Today I dropped off the exhaust pipe for the Aquahot to finish that up soon.
    Mar 2024
    Muncy
    69
    537
    Wow, Wow, Wow.
    That looks amazing.
    Was it confirmed the leak was from the roof? Did you have any rotting in the bus floor?
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    Mar 2024
    Muncy
    69
    Yes the floor was very bad under the fresh water and gray water tanks , we replaced the plywood with PR. TREATED Plywood ! We tested the tanks when we had them out , no leaks so it had to come from a roof leak ? The bus is still inside and no water from all operations inside the bus !
    Mar 2024
    Muncy
    69
    Not any signs of a leak inside the bus !
    Mar 2024
    Muncy
    69
    I still think it’s the roof but I have not had it outside yet . I don’t have a lot of room where it is at to get on the roof ,when I move it to the garage at my house I have a cat walk to go out on the roof without a ladder��
    Mar 2024
    Muncy
    69
    This is one of the before pictures
    Mar 2024
    Muncy
    69
    We are putting in the last pc.this week it wo
    ill cover the hole by the hose and shore power then a little calking ��
    792
    Nicely done. What is your next project?
