OK, on my 99 Marathon XL45 there are 2 switches to turn on the Webasto. 1 is for the hot water and the other is for the base board heat, they call this 12 volt water heater and 12 volt heat. When I turn on the 12 volt water heater the thing turns of in about 1 or 2 minutes. When I turn on the 12 volt heat, life is good and all floor heaters work great.
I think the flow of coolant thru the water heater is not good, the inferred gauge shows that the coolant will shot the furnace off at about 140 degrees. I have checked all vales to make sure they are open when told and I think all is good there. I used compressed air to check for blockage and come up with everything appears to be OK. I blew there the water heater with the old mouth (bad taste) but I think its OK.
Has anyone ever had this kind od Webasto problem. I think the coolant is not flowing thru the water heater at a high rate but I have no way to check it. I lost about 10 hours and 5 gallons of coolant today, not to mention 3 new ball valves just to make sure!
HELP,
Kevin
