Results 1 to 4 of 4
Thread: dash air.
    Aug 2020
    lake havasu city
    91
    Default dash air.
    HI. has anyone had a slow freon leak in the dash air. I have added dye and sniffed everything I can reach. still losing freon each season some times twice in a summer. all comments will be read. thanks. TERRY.
    99 marathon xlv 45 #547 red ram 4x4
    May 2019
    Leesburg
    526
    Friend had a small leak in the dash air that he chased for almost a year. Turns out it was a slow leak on the compressor shaft seal. Found it by using a ultraviolet light and saw small speckles all around the compressor clutch.
    Chuck
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
    2014 Jeep Grand Cherokee Diesel
    Aug 2020
    lake havasu city
    91
    GOOD info. will follow that one. compressor was replaced by marathon prior to my ownership. thank you
    May 2019
    Leesburg
    526
    Dye was installed in the system and provided the speckles by the compressor clutch that could be seen by the UV light. Sniffer never indicated a leak at the seal and dye was not enough to see without the UV light.
    Chuck
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
