Results 1 to 10 of 10
Thread: Tire Pressure Monitor Recommendations
    Dec 2020
    Goldsboro
    145
    Default Tire Pressure Monitor Recommendations
    What do you use for tire Pressure Monitor with a toad
    George and Joan
    1998 Royale Aug 2019
    Goldsboro NC
    Just added a 2022 Ford King Ranch
    802
    Seems like most people talking about this on POG are using TST or Pressure Pro.
    Oct 2019
    Montgomery
    64
    I would say to NOT buy a TireMinder setup. I have (had) one on toad and bus - recently took them off because of dissatisfaction with performance. NFG. I’m open to suggestions as well!
    Dec 2021
    Midlothian
    38
    Following as well and interested in the two that Mark suggested.
    Mike & Jodi
    2006 Prevost Legendary
    Dec 2019
    Brodheadsville
    251
    Mike,
    Take a look at this. https://rvibrake.com/products/rvibra...f642703a0d0993
    they have a complete brake system and air pressure monitor for all axles on the toad and your bus. Getting it set up takes a little installation. I had the whole system installed in about two hours. The key is placing the hub within good distance of the toad and the unit at the dash board. It works very good. Only draw back I had was if you let the tablet go dead it takes quite a while to get it charged up and running. I found that if I plug the tablet in about an hour before I am ready to go it works flawlessly. The directions are easily understood. Check it out. It's another option.
    1995 Liberty XL
    Chris & Sara Jo Behrens
    802
    Good Morning Chris!
    I did not know that RVI was doing this. Where did you end up putting the hub so that it was able to see the toad and the front tires? Also what did you do to mount the sensor on the inner dual?
    Dec 2019
    Brodheadsville
    251
    Good morning back to you Mark!
    I put the hub mounted on the side of the wall in the bedroom with a direct sight to the tablet. I don't use sensors on the coach, only the toad. Before I invested in sensors for the coach I wanted to make sure they worked well, which they do. I'm going to invest in the coach sensors before we break the lady out of the garage in May. My inner wheels have valve extensions that pop out thru the outer wheel holes so they should screw on just fine.
    1995 Liberty XL
    Dec 2020
    Seattle
    30
    Quote Originally Posted by georgiapeachinc View Post
    I had the entire RVi setup. The valve stem caps cannot handle the pressure of the bus tires. I found out the hard way when I had 3 crack and blow out. The company replaced them all free of charge, but I had one more (replacement) crack.
    I removed the entire system as it was more trouble than it is worth. The rest of the their products are great.
    Dec 2019
    Brodheadsville
    251
    Jamie, Thanks for the review. I can pass on the coach sensors. But the toad sensor and brake set up work fine.
    1995 Liberty XL
    Aug 2019
    Spring
    87
    Quote Originally Posted by Dockholiday View Post
    I have had less than great performance from mine on our Marathon H3. Would replace it if feasible.
    Mike
    Michael & Debra
    04 Marathon H3-45 0851
    Matching ATC Silver Trek Stacker
    TOAD: Jeep Gladiator
    Houston, Texas
