Results 1 to 6 of 6
Thread: Trace Inverter Cooling Fans
    Jan 2021
    Bourbonnais
    6
    Default Trace Inverter Cooling Fans
    I have a 1999 Prevost Royale with 2 Trace SW 2512 inverters. The bay that they are in always seems to be very warm. My assumption is that the cooling fans are not working. First, can I find replacement fans for the inverters that will work or, do I need to put my own fans in the bay to help with cooling. Any advice is greatly appreciated.
    Thanks, Jeff
    Dec 2020
    CASSOPOLIS
    35
    Jeff, I just replaced my Trace inverter fans. I called inverter service in Tennessee and they gave me the fan numbers and I ordered off internet. My trace inverters are larger than yours so I am sure your fans will be different.
    Jan 2021
    Bourbonnais
    6
    Thanks Mark. I’m also working with Inverter Service Center in White House, TN. Randy told me that they don’t make that fan anymore and he can’t get any used ones. I didn’t want to give up so here I am searching. Hope to fine something that will work. After all, it’s just a simple cooling fan….isn’t it? ��
    Dec 2020
    CASSOPOLIS
    35
    Yes very easy to change. I am sure you can custom fit any fan off ebay or amazon to fit as long as the voltages are the same.
    870
    McMaster Carr has a bunch of cooling fans to choose from.
    https://www.mcmaster.com/cooling-fans/
    Mike Giboney
    1992 Prevost Country Coach
    #60187
    Dec 2020
    CASSOPOLIS
    35
    I have three addition fans that I installed in the bay to help cool the bay. One mounted on a tube sucking the heat from the ceiling, one at bottom of bay sucking heat out and one mounted in between my inverters to move air in-between them because mine are stacked. The bay stays a lot cooler and doesn't transfer so much heat up in the coach.
