Results 1 to 7 of 7
Thread: Rooftop AC bearing
    Default Rooftop AC bearing
    08 Marathon. RTU screams on startup. I pulled cover and when I spin the fan it growls bad. Feels like a bad bearing. Has anyone replaced this? If so, what did you do? Advice appreciated.
    Tony and Jenny Conder
    Abilene, Texas
    2008 Marathon D/S XLII
    2017 RAM 1500 4x4
    Apr 2018
    Crossville
    256
    Is it an 2008 original?
    Les Stallings
    Crossville TN
    2006 Country Coach XLII
    4,523
    Tony,
    The outside fan motor should be readily available. Get the rubber mounts too while the motor is out. Make sure the fan is still good. It's pretty common for them to eventually get loose at the shaft.
    Repairs complete. This was a Royal PIA. The motors needed to be replaced. The motors are obsolete. At Marathon’s direction I found some for sale on eBay. After swapping motors out I found that the shaft of the motor did not come threaded so there was no way to fasten the exhaust fan to the shaft. I dug around and found an old tap that I could use to thread the shaft. That was successful. I swapped out the capacitors while I was in there. So for $340 in parts and a significant amount of frustration, my wife and our traveling zoo are once again cool and comfortable. Oh, and it is much quieter now. If you think you may need this repair in the future you should probably acquire a motor or two.
    Safe travels all!
    Abilene, Texas
    2017 RAM 1500 4x4
    Sep 2008
    832
    Way to go Tony!!
    Pete & EJ Petree
    Sealy, Texas
    4,523
    Tony, nice job! I'm surprised those motors are already obsolete.
    Planned obsolescence I’m sure. Marathon still uses the Coleman Maach 8 on its new coaches, but it is a newer design with different parts.
    Abilene, Texas
    2017 RAM 1500 4x4
