Results 1 to 9 of 9
Thread: 24 volt Alt. oil leek
    Quote Originally Posted by Just Plain Jeff View Post
    Joe: This is the message you may not want to read.
    Anyway, we had an ongoing problem with our 1st camper with this very issue. We tightened, replaced gaskets, etc. Turned out there was a bad seal between the cover and the first unit (if you look carefully from below, these units are in 3 pieces). Finally had to replace the alt.
    Hopefully this isn't your situation!!!
    Check oil level frequently as the oil lubricating this puppy runs off the engine oil supply.
    If it keeps leaking, the good news is that you can extend oil change intervals as you wind up putting about 2 quarts/1000 miles in the engine. (Sorry, couldn't resist).
    GOOD LUCK and hope that the gasket gets it done.
    Jeff, Did you "finally have to replace the unit" for the oil leak or was it some other malfunction? ( just wondering for clarity).
    lewpopp Guest
    Hell No, Jeff just traded it as he does every few months.
  1. 24 Volt Relay
    Last Post: 01-25-2010, 11:54 PM
  2. 12 Volt Thermostat
    By truk4u in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 06-26-2009, 11:55 AM
  3. 24 volt to 12 volt for a reailer brake controller
    By billbunch47 in forum Sparky's Corner
    Last Post: 06-06-2008, 11:33 AM
  4. 24 Volt taillights
    By ken&ellen in forum WANT/NEED PARTS?
    Last Post: 05-03-2006, 07:56 PM
