Just to add a bit, I was adjusting the brakes after I was done with the seal job. When I released the air in the brakes, took it off park brake. I heard a leak in the air line. It was the line that feeds the drive axle to keep the spring from setting the brake in case you loose air. It had to be leaking for a while, just can't hear it while you driving down the road.
I don't think I have ever checked for leaks with the park brake off.
Learned somthing else today.
