Anyone have a 24 volt chassis battery charger that is a smart one. Reduces the charge as batteries get charged and maintains batteries.
Anyone have 12 volt maintainer for generator battery?
George and Joan
1998 Royale Aug 2019
Goldsboro NC
Just added a 2022 Ford King Ranch
These are very popular.
Mike Giboney
1992 Prevost Country Coach
#60187
U do not want a 24 v charger for your chassis. U want one like Mike posted only, one that charges 2 12 v banks. If u have 1 of your 4 chassis Batts go bad a 24v will roast the other 3 trying to keep voltage up. 2 12s will not do that and won't hide the problem either u will catch the bad apple by getting a batt imbalance early on.
Yep, this works really well.
Les Stallings
Crossville TN
2006 Country Coach XLII
Here is how I hookup my Battery Tenders to charge two parallel twelve volt banks in series to get 24 Volts with my current battery tenders. I will be buying a Guest charger soon and connecting it the same way. Anyone rewiring this area of the Bus should see how Gil uses Bus Bars. It's a much cleaner setup.
Mike Giboney
#60187
Any downside to using a small fused set of alligator clips on the CHASSIS and HOUSE terminals of the jump-start solenoid in engine bay when parked, and letting the inverters maintain the chassis batteries also? I do realize a shore power loss in that scenario would also deplete chassis batteries along with house batteries, but it is stored here at home so not much of a concern.
I can't take credit for this idea (it was suggested by Rick May) - however I have done this since Dec 2018 and has seemed to work well.
Billy & Lisa Gaines
1996 Marathon XL40
