6 Attachment(s)
Repair Broken Zip Dee Z-Lock
For those of us who have manual Zip Dee awnings, it is not uncommon for one of the Z-Lock mechanisms to be stripped or broken. The Z-Lock is shown in the 2nd picture. The last picture shows the inside of mine that was broken with 9 teeth stripped. Sometimes this is caused by placing the lock in the closed (up) position while the awning is out. If the top brace is not in place the wind may blow the awning and cause the Z-Lock to strip the internal gears. The front one on my 23' awning was stripped as shown in one of the pictures.
I called Zip Dee and ordered the Z-Lock mechanism and installed it. I was surprised how simple it was to make the repair. They sent an instruction sheet with clear guidance. It only takes about 20 minutes to make the repair and anyone with simple mechanical skills and a few common tools can do the job. The lock on the front side is not attached to the spring mechanism, so you don' t have to worry about that during the repair. I just drilled out the rivets, removed the mechanism, installed the new part and reattached the arm. I rested the end of the awning on an 8' ladder and tied it to a stake in the ground so the awning couldn't roll in while I had the end off of it.
Picture 1 Shows the arm that is always dropped down because it is broken
2 Repair kit including Z-Lock, new screw and rivets
3 Punch to knock out rivets after drilling
4 Wrench and screw driver used to remove the head (with red Zip Dee name)
5 Required tools
6 Broken mechanism
