I sure miss Lew!
Jim,
I would not recommend isolating the compressor from the system to add oil unless you draw down the compressor under vacuum to remove the air and moisture that you introduce by opening the system. In order to repair the compressor, change or top up the oil you must place the compressor under vacuum to remove air and moisture introduced during repair.
