To get those little bulbs that go in the push button switches ( go from green to red) that control lights and the house systems?
Kevin States in parts at Featherlite Coaches Inc. has them.... His # is 407-323-1120 ext:108 ... as I recall they are pricey lil dudes... $7 or $8 a piece.. I bought a dozen about a year ago as he said they were very hard to find. I have been trying to find another source.. will let you know if I do. Good luck !!
Diane
That was my experience..just thought they could be a lot less expensive from a supplier. Tried running the various numbers I found on the bulb to no avail.
Granvil,
Have you tried this place? I have had some luck getting a few small bulbs from these people.
http://www.mouser.com/
Plug your numbers in the search box.
I found the following on bag they were in 1460145( was in bus when I bought it ) and odp rg 12
Ok, I am told the bulb is an LED # 386, midget base , Bi color. I found the bulb but not the bi color version.
Okay... after a few hours of research I have found the Manufacturer of the lamp you are looking for... this is very much like the #386 but it is bi color.. my lamps from Vantare were stamped DDP R612 so I found an electrical company that is DDP Inc. and sure enough they make the correct lamp. They referred me to 2 different resellers ( and also told me that they never have them in stock but they take orders for them in lots of 25.) and one quoted me $3.63 each and the other said $4 each for 25 min. order and $3.70 for 50. also it takes 6-7 weeks to get them after the order is placed.. I have copied one of the replies here that will give you the correct item number.. maybe there are a lots of Poggers that would like to have some and we could make up one big order... here is the information I have..
Good afternoon Diane,
I have received your request for quote from Laura and your cost for part number MG200-LRG12H is $3.63 each with a 6 week lead time from the factory plus shipping. Carlton Bates has a $25 PO minimum. Please feel free to contact me for anything else!
Thanks
Amanda Baumbeck | Inside Sales Rep
abaumbeck@carlton-bates.com|
office: 501-235-4193| fax: 501-235-5122
QUOTE=grantracy;74194]Ok, I am told the bulb is an LED # 386, midget base , Bi color. I found the bulb but not the bi color version.[/QUOTE]
Thanks...I will probably just order 25...there are probably twice that many in my coach.
If anyone needs the clear 386 bulbs, you can get them here for 4.60, a box of 10: http://www.replacementlightbulbs.com/lamp386.html
