Changing front and rear clearance lights out for LEDs
In changing out the marker lights on the top of the front cab and on the top of the rear, there are a total of 14 lights (7 amber in front and 7 red in rear). As I read the potential amp draws of the LEDs I want to use to replace the normal bulbs of 'a '98, I see readings of 1/10 th amp per replacement light. These are very nice multiple LED lights. Does any one know the maximum draw per set of these replacement lights that can be used? Is the in-place wiring sufficient to handle the new draw down. It might even be less than the current draw down being experienced.
Thank you.
PRES
