Window Leak Passenger Door
2005 XLII leak around the small moveable passenger window. Noticed the leather at the bottom of the door panel was coming apart. Took door panel apart to discover extensive water damage from leak around small sliding window. Water tested and found water leaking from all around window seals. Does anyone have experience with this issue? Does replacement of the Prevost window moulding, felt and flap seal solve the problem? Also, not sure how to go about replacing these parts if this in fact will solve the problem. I have heard there may be a water track of some type in the doors that channels the water outside. Does anyone know if this is correct, and if so, where it is located? Any ideas or experiences on these issues? Thanks Dan
