Jimmy C,
I thought your pump ran, but like mine, won't pick-up a prime probably due to a bad impeller!
Jimmy C,
Tom, I can not feel any vibrations of it running and I can not hear it run. So I'm assuming it's not running. That's as far as I have gotten with it for now.
I can't turn the shaft with my fingers I can't "rab" it.
If I knew the dimensions I asked for I could cross drill a nut so it would fit the shaft and leaving the drill bit in the nut to engage the slot, I think I could rotate the shaft with my finger tips. As you know it is barely assessable in its location.:mad:
I won't comment on your spelling Jim, but will comment on the remark about it not making a noise.
Have you verified you have power to it?
When it gets power, even if it has lost the prime, the macerator on mine makes a very loud noise. Start with the basics before you start considering the more complex stuff, And if it is getting power, just reach in there and remove it so you can work on it at your workbench. When you reinstall it nothing says it has to be returned to that exact location.
