What's the best source for the Parker fittings?
If u haven't been able to pin down a local supplier I can give u mine. I put phone orders and they ship to me everywhere. Even when shipping is involved prices r good.
Precision Hose
Lansing Il
708 474 4466
Joe,,
I need help fixing my air system, been looking around for best fittings and hose to use and found this post,
Question, Did anyone ever create a list for air system fittings and hose sizes ? where to purchase, Etc ??
Also found lots of info on making your own leak detector found a lot of people saying they make their own, but no recipes ?
Rick
U want a rundown of the suspension fittings specifically?This is what I was refering to.
If u r after brake tank or aux air issues that is not something I can just put an order togeather in advance on.
Let me give u some common leak points for chassis.
The parking brake button both out the stem and at the fittings both.
Open the dash lid and check the fittings at the gauges
The seat both above and below the floor.
The black 1/4 in signal lines to 2 of the 4 above the rear suspension brake relays. On an h u can listen and sniff those by pulling 1 or 2 house batteries over the drives. They r push in fittings.
The push ins coming off the brake pedal valve under the drivers seat.
Air tank drains.
Aux is more Liberty specific but check the stems of the ride height valves where the arm mounts up. If it leaks there with key off that's chassis aux air leaking.
I use amprobe Amazon has it. Takes practice and it's not a do all end all. I also listen and paint dawn dish soap straight with a small artists brush.
My supplier is Precision Hose
Lansing Il
Tell me if u r doing the suspension I can put an order togeather for u.
Good luck.
