Flashers quit working
Oooops. While trying to change a dead bulb in my Psgr Side first clearance light, I inadvertently made contact with both small "leafs" that provide power to the two bulbs, and.....zap. Not me, but I saw the arc. Now I have no flashers working (it was the top tier). Can some one of you point me to the what the problem is? My first guess would be that I blew the Flasher unit. Even the Emergency flashers do not flash. Also, if this is the case, where is the flasher located? I looked around under the dash but I don't see much, a couple of relays and some heat ducting, also the control switch for the Alarm that is not hooked up. Could use some help, we just North of Colorado Springs visiting kids and won't leave for a couple of weeks. Also, since this is probably a 24vdc unit, any idea on where I can get a replacement, a local Freightliner dealer was dubious that I would find one short of ordering one maybe from Prevost.
Probably just the circuit breaker. Check in the access door, outside driver side and the row of breakers will probably have one popped. Just push to reset and you should be good to go.
I did the same thing a few weeks ago (without the flash).
Maaaaaa
Thanks Jerry, as you might guess, feeling a little sheepish....and that may be dangerous~!:)
