Anyone have a 24 volt chassis battery charger that is a smart one. Reduces the charge as batteries get charged and maintains batteries.
Anyone have 12 volt maintainer for generator battery?
These are very popular.
http://forum.prevostownersgroup.com/...id=17285&stc=1
U do not want a 24 v charger for your chassis. U want one like Mike posted only, one that charges 2 12 v banks. If u have 1 of your 4 chassis Batts go bad a 24v will roast the other 3 trying to keep voltage up. 2 12s will not do that and won't hide the problem either u will catch the bad apple by getting a batt imbalance early on.
Yep, this works really well.
http://forum.prevostownersgroup.com/...id=17289&stc=1
Here is how I hookup my Battery Tenders to charge two parallel twelve volt banks in series to get 24 Volts with my current battery tenders. I will be buying a Guest charger soon and connecting it the same way. Anyone rewiring this area of the Bus should see how Gil uses Bus Bars. It's a much cleaner setup.
http://forum.prevostownersgroup.com/...id=17293&stc=1
Any downside to using a small fused set of alligator clips on the CHASSIS and HOUSE terminals of the jump-start solenoid in engine bay when parked, and letting the inverters maintain the chassis batteries also? I do realize a shore power loss in that scenario would also deplete chassis batteries along with house batteries, but it is stored here at home so not much of a concern.
I can't take credit for this idea (it was suggested by Rick May) - however I have done this since Dec 2018 and has seemed to work well.
