2 Attachment(s)
OK I am ready to look under the bus, I was wondering if these are the correct body points to put my support stands. I have 4 of the 22 ton red and blacks from Amazon.
Front:
http://forum.prevostownersgroup.com/...id=16910&stc=1
Rear:
http://forum.prevostownersgroup.com/...id=16911&stc=1
1 Attachment(s)
Here is the dimension of the rear, i was concerned about raising the bus up above ride height, not sure if it worked or how high i could go. I could raise the front and both sides but not the drive direction.
http://forum.prevostownersgroup.com/...id=16914&stc=1
Hi Jon, I just found this posting. Are these stands still available? I have a 1990 XL40
Any steel fabrication or welding shop should be able to make what you want for not much money. The jack points should be illustrated in the service manual.
