The Pressure Pro Pulse works good on a 40’ XL with the Dipole antenna mounted high on the center post.
Tom,
Thank you for this information.
Reese
Gil,
They changed Sensor designs and the new Dynamic Sensors won’t work with the original Echo Repeater. They’ve been promising a new Repeater, but still not yet available. The external antenna works well, gets the antenna back about mid coach and solves any rear or toad signal loss. I did my 02 Marathon and it worked well. At least with the FX you have the flexibility to mount the module anywhere in the bus that gives you good signals. Some can mount up front with no problem and some have to find the right spot. Seems to depend on the coach and I assume electrical interference may apply, you’re the expert.
