Parts Dude,
There's no crying in Nascar, I couldn't believe it either!:o
Parts Dude,
Parts Guy,
I assume you are with Prevost so you have access to substitutions and pieces and parts not found in our parts books. So far, to the best of my knowledge Joe is the only guy in POG that has a coach with those valves. If you want to really have a good impact on POG folks, outline the changes required to stop the older coaches from dumping tag axle air when the aux pressure drops below a certain value. There are several on this forum that would likely spring for the fix.
Excellent suggestion Jon.... I believe the Prevost part number for the kit is
9614A, Reverse Tag Logic, but I don't see it on the parts list. I for one want to do this fix asap.
Jon it seems like there may be only 1 conversion regardless of the vintage. We will see. Hector already posted it somewhere.
Here is the thread that addresses the kit available for coaches older than 1995 - 1996. Mine is a 1995 and the suspension logic will release on low aux air pressure.
http://forum.prevostownersgroup.com/...ead.php?t=2685
In post #7 is a link for the Prevost instruction for the upgrade and in post #16 is the price I was quoted.
I would be interested in hearing of the results of anyone that attempts to install this upgrade. I decided to keep my aux air system 'tight'.
Hector
