I am looking to replace the square tube lighting in the bus windows. Does anyone have a website to order these?
Sandy
Sandy
If your talking about the rope lighting I have a bunch that you can have very cheap. 559-901-6426
Hi,
I also like to know where to get the square tube lighting for windows and under countertop,
Alek
SANDY.......... I DON'T KNOW IF YOU CAN PUT 120V AC LIGHTS, MY '05 THOMPSON USES THEM AND NOT ONE THEM HAS BURNT OUT YET DARRELL
I think this is them:
http://www.vistamfg.com/products/316...e-Krystal-Lite
John,
Thank You for the link,
Alek
Also, Tivoli lighting will have it.
http://www.tivolilighting.com/Produc...t_Fastube.aspx
I see that Vista also makes the square lighting in LED version. I'd go with LEDs. They last longer and use far less power.
We've dealt with Vista in the past. They did a fine job for us. I believe Tivoli produced the original window lighting in our Liberty however after giving Vista exact measurements on tube size, light spacing, and segment lengths, they produced exact replacements. Am about to order replacements on our Royale. I agree with Gil and will use the LED version
Go with Vista. Tivoli is not a consumer friendly company, meaning they will not give you the time of day. The "gentleman" there said, "where did you get the first lighting, go back to them. We don't deal with the public", end of conversation.
If they dont deal with a retail customer than they should tell you of one of thier distburators so you may order what you need .
The Tivoli Lighting can be found thru retail lighting distributor in your area. The Liberty Coach is 24 volt and the Tivoli lights or similar connect directly to the lighting relays thru the existing wiring. When using LED lighting, they are normally 14 volt and a LED Driver is required.
So do your research prior to just ordering LED.
Thank you all for this info. Will now start researching these companies. I have also found a company called Starfire Lighting, Inc. that has these.
Sandy
