Powertech Generator Voltage Spike
Today I noticed one of my Trace Inverters was kicking on and off with my generator running. I have a Powertech 17.5 KW. The leg on the inverter that was kicking off was showing 130 - 133 volts. The other was in the 120 - 121 range.
It worked perfectly when there was no load, but when I turned on a AC it spiked. When I turned on two cruise airs it spiked to 140. When hooked up to shore power Trace inverters work as they should.
The generator engine sounds and runs great. Do I possibly have a regulator issue? Or possibly something else with generator?
