Orren,
Picked this up today. Figured I could get multiple uses out of it and priced cheaper than a Transmission lift. $99.
Attachment 5985
Harbor Freight #2792
Orren,
Attachment 5985
About a month ago I could have used that to remove and replace my 8D house batteries. Without it I had to balance them on a hydraulic floor jack. It worked the way I did it, but your motorcycle lift would have made it much easier.
Where was that when I needed it?
He's still busy trying to bling up the CC so he wasn't available to do the heavy lifting while I supervised.
I don't think he would have wanted to help. I sold the old batteries for scrap and found they weighed 170# each. If I knew that before I started I would have delegated the responsibility.
Thats what I use and if you two were Bikers, you would already have that in stock!:rolleyes:
I think I paid a lot education dollars.
About 12 hours of work over 4 visits to finally find the problem. There are two inline fuses buried in the control box attached to the generator. One was blown (250v / 8amp Slow Blow) and we thought that was the problem. Changed and immediately blew again.
Finally traced it down to the voltage regulator board also located in the control box. Haven't seen the price yet on that board.
With all the hours spent trouble shooting I just wonder in the future if it's just cheaper to change the boards. Plug and pray.
This is the only authorized Kohler dealer in the area and they handle the work for 4 states.
Mike
I have been told that the shaft bearing is something to look at around 5000 hrs. I got that from the owner of Martin Diesel that supplies lots of generators to different builders.
