bus air fan motor won't shut off
On our way home from our first trip in our bus we experienced temperature extremes that had us running A/C during the certain hours of the day and the heater at other times. During a fuel stop, I noticed that when I shut the bus off, there was still a loud fan noise coming from the middle starboard compartment that is secured by screws. I popped it open to reveal the fan for the bus air and it was running. I checked the ignition and also the dash switch that controls air/heat for the bus OTR air and both were off. Ordinarily when I shut the ignition off the fan would also stop. The most immediate way to shut the fan off so that it wouldn't just run off of the battery (I'm assuming this would run off of the chassis battery) was to throw the 24V kill chassis kill switch. I tried cycling it to see if there was a fault that would clear itself, but it would just come back on. During the remainder of the trip the fan continued to run. When I got home, I again shut down the 24V. Is this issue likely to be a faulty relay that is located behind the driver side exterior electrical panel? Anybody run into this problem before?
Thanks,
Devin
