Post more Judi, that's the right way.
Judi, another solution for your not knowing which way to go, is to change out the toilet to a Royal Flush Superbowl. No Air Required!!!!!
954-581-6996
Then your only concern is the pocket door. I know a guy you can ask about that.
If you present your solution properly you will get a new matching sink and a redecorated bath area ;) :)
Seriously, be sure to repair your air leaks. Don't get into the downward spiral of deferred maintenance. It leads to a pit of no return.
:D JIM
"It leads to a pit of no return."
Wow..... truer words were never spoken, er typed....
Ok, time to take my thread back from the thread-jacker. :)
On a related note from the TJ, my toilet doesn't work again, but this time it's the air. I checked the aux air tank, 30psi, the compressor isn't coming on, and I checked the fuse, it's ok. So I don't know what the deal is, I'm assuming something is frozen, any help here would be appreciated.
Not sure what kind of compressor you have, but if it takes oil, make sure it has some, if you can turn the pump by hand, try and see if you can, check voltage at the compressor, and if possible find the pressure switch, use a jumper and bypass it.. That too could be it.
