Hi all,
So I rebuilt my ISRI drivers seat and I thought I would pass along this info.
$5.00 bucks and a used air regulator and I had a custom air controlled seat.
Attachment 16165
the 4mm ( 1/4" air line " black tube " ) is reduced with a fitting that is not available, I had to build this connector, it's 1/4" X 2.44mm.
the tubing ( yellow ) is 2.44mm, I found this at my local Parker fitting store.
here is the receipt so you can see exact part numbers.
Attachment 16166
I also installed a air regulator that supplies air to the airbag under the seat, now I can adjust the air pressure for a softer ride, It works really well. I put the regulator behind the drivers seat to the left.
Hope this helps someone.
