Yo Jeff so tell us what was it like pulling that large new trlr over the mountians. Everything O/K we all hope?:)
Joe- I just now got the car loaded after taking my sweet time securing the misc junk to the top level of the stacker. Plenty of room to spare if I want to stop and buy junk for the new house on the way back I guess. So it's 5:30pm PST and I'm ready to shove off. Might leave tonight. More later I guess. I drove here to CA using 1-10 but can't remember what I went over for mountains. I can tell you that it's more than a fly back there. I guess I'm around 16,000 pounds with the car and stuff since the trailer was 12,000 pounds empty. I'd like to weight it somehwhere but I don't think I should stop at the scales off the hwy and take a chance of getting scrutinzied for the length. Don't some truck stops have scales ?
Go on line for www.flyingj.com and they will tell you where all of them are and they all have scales.
Lew
Just checked fuel prices on that site 2.39 in Gary Ind.
Did ya ever think we'd be happy to be paying that:rolleyes:
I think the cheepest I saw was 2.35 over Jon and Rodgers way.
I left Carlsbad alright X-Mas Eve and put 300 miles behind me. Just stopping now at 2am. The first 70 miles sucked and I could already tell I didn't want to fuss with a trailer this big long term but it was mostly due to climbing 4,000 feet in only 50 or 60 miles. I crawled along at 35 miles an hour in 3rd gear sometimes. I figured out to keep the RPM's up in 5th gear prior to hitting the hill and it helped but there is a very noticeable drop in climbing power. I'm sure this is not anything new for most of you seasoned owners but this is a first trailer pulling experience for me so any additional tips welcomed. I had it up to 85 MPH and all ok.
After getting over the first round of hills and getting on a flat straight road I'm not as pestamistic about the trailer. Not sure what the opinion will be after 3k miles.
I think the better part of the extra strain from the load is on the transmission more than the engine. These engines go in semi's do they not ? The transmission they pair up with it different though. Like a 13 speed manual I think. My arm chair mechanic guess is that the greater toll is on the tranny. Confirmation welcomed.
One thing I could use some advise on is how to best reduce the chance of exhusting / overheating the turbo when climbing over the mountains. The boost would hold steady at around 23 while climbing. My first bus had a temperature exhust gauge to give you some help about on temp and it changed very rapidly in a hill that like unlike the water temperature. It is absent on this bus. It seems like my acceleration rate decreases for a bit immediatly following a climb for several minutes as if to suggest the turbo is tired. It almost feels like the turbo is not working at all although I'm still showing boost. Seems like acceleration is slower and almost non exhistent even if I'm leveled off. Could be my imagination. Throwing it out there in case I'm not imagining this.
Dude! Do not pull into a state owned scale house! That's just asking for trouble. They get paid to remove money from your pocket and they are good at it. Most all truck stops have scales and will weigh you for around $7. The best are "Cat Scales" that are guaranteed accurate.
Going from never even pulling a toad to 16000lbs on the hitch and then right over the mountian to boot. Thats why I asked the question in the first place:p
Let me put your mind at ease about the pyro guage though.
I'm guessen your probably around 60000lb or so and you are correct those motors are built for 80000. Add in the fact that it is cool this time of year and the exhaust gas temp. isint gonna be a factor. Id be watching the trans temp guage though. Im sure its gonna preform just fine in the flat.
Hows the brakes. I'm also guessin that 3 more braking axles with only an additional 16000 might actually improve braking?
I was at marathon in florida and i spoke with a coach driver of a newer marathon and I asked him what his h3 weighed and he said 62000 lbs.then i asked what does your stacker trailer weigh he replied 20000 lbs.We talked for awhile and he told me that the coach has a 4.86 rear gear and it will pull to 2300rpm which he said a texas trooper friend of his radared him at 108mph late one night,the DD60 is made to pull 80000+lbs in hot weather,but there is nothing wrong with checking the gages.
I'd a never guessed that an H3 weighed that much. Do I dare say that's too much for a camper:rolleyes:
108 hu? whew
By the way, hello Jack, welcome to the club and MERRY CHRISTMAS!!!!!!!
the h3 is owned by a nascar driver I am sure it is full of marble and granite,also it is a triple slide.the stacker trailer has a tahoe,two harleys,and a golf cart inside.I would not want to buy a coach that starts out that much over gross.
Jeff,
If I could make a suggestion, take it easy and don't push it. In the long run you will make better time because you won't be sitting on the side of the road waiting for help. I have a trailer that weights in at about 16K or 17K and this past summer we saw 150 degree tire temps, you are lucky to be making the trip when the temps are low but still take it slow, 60 or 65 max and everything will stay happy, including your wallet.
Kevin
we towed a box trailer with car and bike (approx 8000 lbs total) this summer from south connecticut to approx 1700 ft level in randolf vermont.
not nearly as steep as the section of 77 just before getting to 81, more like a long low rise with lots of dips.
we got an amazing 3.7 mpg on that trip! :-(
i got a valve adjust at a DD shop in middletown ct - maybe i'm just imagining it, but i think i can tell a diff - we don't seem to slow down on hills nearly as much. and the pyrometers match much better.
we did a cat scale in polk city florida jsut after pog I - a tadge over 41000. didn't have a trailer in those days tho.
since then we've jetisoned a few things, most notably the washer/dryer - 300 lbs of useless junk IMHO.
QUESTION: is there an aftermkt tranny cooler for these things similar to ones you can get for 4-wheelers?
cheers,
wmm
WMM,
I am thinking that when looking in the rear doors, to the left (which is the RH side of the engine) down low is the intercooler for the transmission on an 8V92.
Even when pulling hard if things are in good shape with the transmission you should match engine temps closely, which is OK. Unless you have something wrong the only way you should ever see the transmission temps rise too much is if you have overfilled it.
Joe- Triple axle; yes, but remember this trailer is not the typical set up with all the axles together. I have two in the rear and the front wheels track/steer so I suspect the brakes were omitted on the front axle although I have not checked.
I would not say my breaking is superior but the trailer seems to be stopping itself at least. The brake adjustment (remember this is a first for me) it adjustable with different levels of that this manufacture refers to as "boost". Boost 1,2,and 3 for 3 levels of aggresivness depending on the payload and also depending on the weight ratio of trailer to tow vehicle. The Boost level gives the trailer brakes a jump start ahead of the tow breaks when you start to break. It feels like it's working as described in the maual. I had on B1 when it was empty and set it to B2 after I loaded it. Also, you turn a second adjustment (a wheel in this model brake sending unit) which adjusts the brakes as well. As you turn it up, the voltage reads out as to what your sending to the trailer brakes. I have it calibrated to read 8 volts when I throw the manual lever. I suppose this doesn't mean much to anyone as it you sort of set the setting (and subseqently the drag) by feel. I think it could stand to go up a bit more.
I can feel the trailer nudge the bus around a littel bit but it tracks straight as an arrow and with the axels offset the way they are the attention to a balanced load is far less critical to prevent it from swaying. The factory (converter?) hitches are rated for 10k pounds someone said and I'm at least 16k pounds but the guy that had this trailer before me had a stock type hitch if stock is correct. I don't know if the converters all put them different or if it comes from Prevost welded on.
Here's some free advice worth every cent you pay for it.
The Prevost rating is critical. That hitch, as set up is attached to the engine cradle. Think of the hitch ball as being on the end of a long lever arm, especially on 45 foot coaches.
As your trailer tongue is set up you do not have any substantial vertical loads, but the side loads (which the cradle is not designed to handle) can be excessive. If I am not mistaken there are Prevost designed or approved hitches for the weights you are towing.
Jon- With my front axle I think I'm getting a little help on reduced side to side motion along with reduced tounge weight. Another benefit to the front axle I hadn't thought of until you mentioned the side motion.
Kevin- I don't think I properly thanked you for taking my call last week on this trailer subject. Thank you. Thank you also for the warning and I will head that caution. I only had up to 85 for a short burst to help getting up a hill. On this subject though, I noticed it seems to be happier at 65 mph keeping the RPM's higher. I think I have less strain on the drive train here. Of course I use 5th gear at 55mph and do the same.
I keep hoping I'm not going to feel a sudden sense of lighter weight only to look in the mirror and see the trailer sailing off into the trees. Weeee. (yes, I have the safety chains attached).
Oh, didn't get stopped on exit from CA last night. Xmas Eve probabley a good choice to escape. I stopped at the AZ Border Patrol check point resisting the urge to "bust the gate going 98 and their ain't no gate no more........let them truckers roll ..10-4". The Border Patrol said I was over my legal limit of Mexicans and made 4 of them get off. I've only got 3 left now to help me drive to Florida.
Didn't anyone get a new bus from their wife under the tree this morning to report on ?
Hi Jeff. I like that. ESCAPE from CALIFORNIA. Sounds like a new Movie.Quote:
Originally Posted by Jeff Bayley
108 MPH.... Hmmmmmm, what's the last thing that goes through a bugs' mind as he hits the windshield? Answer: His ass. Just think about stopping that much weight when a deer darts in front of you. Oh you'll say, hit the bugger, but you won't give it another thought until it's too late and you'll hit the BINDERS. That's automatic. By then, you're SOL.
Lew
I wouldn't worry too much about a bus going 108. Especially with those gears.
Sounds like some fertilizer for my tomatoes.
Just as a comment sure to irritate the hell out of some, every time I see a Prevost go blowing by at a high rate of speed I immediately think about how the driver is clueless. As Lew points out all it takes is a deer to jump in the path or some airhead talking on a cell phone doing the unexpected and my insurance ends up getting another increase because it is going to be a mess.
Our buses do not stop very well. I'm amazed that folks smart enough to buy a Prevost haven't figured out the consequences of driving beyond the capabilities of the bus.
Flame away guys.....
Half that speed can make some emergency stops pretty difficult.... I was driving south on I-77 between Statesville and Charolotte a couple of years ago at about 50 mph when the lady driving the car in front of me decided to stop for the stop sign on the entrance ramp!?!? The concrete barriers in the construction area and other traffic prevented any chance of 'evasive action', thankfully I had left just enough of a cushion between us to slide to a stop with less than a foot of space to spare. Talk about an adrenaline rush
Just to make sure I'm not fingered accidentley for the yahoo going 108 mph.........that was a friend of a friend somewhere above. I only go 85mph for short distances to get a running start up the hill. I'll admit to that which is still probabley cause for admonisment.
Just so there is no doubt where I stand on this Jeff, you are right on the ragged edge.
That is not an opinion, but a fact based on your own posts. I'm not looking for a fight but to offer some more of that free advice. Your trailer exceeds the Prevost weight limit. You can spin that any way you want but 10,000 pounds is the limit.
But by your own admission you not only have exceeded the speed limit by going at 85, but your tires have a speed limit of 75.
Nothing I say will change your free spirit attitude, but you sound and act young enough to consider yourself bulletproof. I hope you never have a fool pull out in front of you, I hope you never have a blow out and I hope your trailer never separates from the ball hitch because if any of those things happen it is going to be very ugly.
Beside being chickens there is a reason us old farts are around to pick on you. We learned from our mistakes.
I feel like a got spanked but only because I respect your opinon. Ouch. Even for a short "get a running start" its a bad idea then. I didn't know that the tires had a 75mph limit. That's news and valuable.
Talking about old vs young though......here's a weird twist of a story that happend yesterday on that as regards being more careful. A case where the old guy embarrased me by his fearlessnesss.
I pulled into a truck stop and found an RV lot they owned way in the back with plug in's and the sign says $15 a night. I joined Passport America for $40 a year and that cuts in half at any of their affiliates (they have a bunch) at only $7.50 a night. I'm staying here for a few days. I look out my window yesterday monring (Xmas morning) and I see an old fart fiddling with his coach and I said to myself "Self, you better get out there and see if that old fart can stand straight enough to hold your new telescopic ladder while you climb on the roof of the trailer and fix the broken vent before it rains in there on all your stuff". Sure enough, he was healthy and strong enough to hold the ladder but when I got to the top of the roof I found the ladder still uncomforabley short to be able to safely get back down. I sat up there fiddling with my body language imagining that it was going to be hard to get down without falling. The old fart said "Hey come on down from there and let me have a look". He marched up the ladder and onto the roof so fast it made my head spin and fixed the vent and came back down the ladder without incident. I felt like a weenie.
There's one for the old farts. The guys used to be a painter he said and worked on ladders all the time but that sure surprised me.
What I'm most afraid of regarding the bus is having a front time blow out at highway speed. I've heard that holding the bus straight takes all your might. Anybody ever had this happen ? I saw a bus for sale advertising that it had a safety device to help keep the coach straight in this event. Don't know if they work or how much they are to install but that sounds like a good idea if it works. It was described as "Howard active steering option. Holds the steering wheel straight in windy conditions or in case of a tire failure."
Jeff,
I'm sorry if it came across like I was spanking you. I was trying to help you understand everything we do has limits, and these buses certainly have their share of them.
I know a fellow that has personally contributed to our high insurance rates. He was very proud of his high speed driving. Right up until his late model Marathon was rolled into a ball due to a blow out.
I admit to getting preachy on this forum because some folks seem to think such things as weight limits on axles, tire pressures (based on the weight the tires carry), tire speed limits are only suggestions. They are not. If people that ignored these limits were only exposing themselves to the consequences my attitude would be a whole lot different, but because these buses are so big and heavy, a lot of people could be seriously affected just because someone doesn't know or care about the limits and why they should be respected.
When you say old fart, watch out for Harry. He is a little sensitive in that area.
Jeff,
We're all still in the learning phase when it comes to the busses. It seems like every trip out I learn something new. Which hopefully will add to my knowledge base and keep me safe, happy and maint. free on the road. Just soak it all in and keep reading the posts.
I have the Howard steering assist on my bus. I have no idea what affect it will have on a blow out, but would like to know. I will tell you that it works great in a crosswind. Like trimming a rudder on a plane you just set it and it will track against a crosswind with ease. It came with my bus so I can't give you and idea of cost or installation.
Attachment 647
Good luck on your trip.
Mike
The Howard steering is designed to be fail safe, it can't cause any steering issues. I like it, works great when trimmed properly.
Jeff - There are several add on steering devices, I have had several of the Safety Plus Systems and installed them myself. This is a large shock absorber added to the steering linkage. It did help the plastic coach from the tail wiggle due to whimpy wheelbases. You can buy these at Camping World, but I see no reason to ever add one to a Prevost.
Flat front tire - Yep, have had two, always in 18 wheelers and no problem.
I'm going 60mph nice and steady and no problems except that I want to get the brakes checked. I stopped to rest / sleep and went around and felt the hubs right after stopping and burned my hand it was so hot. The other 3 hubs were ice cold. I suspect the brake my only be working on one wheel or the hub may need grease . I stopped and felt these a few times along the route before leaving CA and never felt any heat before.
My 94 Marathon came with the Howard Steering and it is a really nice system.
Not only does it keep the bus going straight down the highway when you are in a crosswind, it also reduces the steering sensitivity a little so when you are on the freeway the steering inputs are less to keep in the lane. Easier driving.
Once while driving across Iowa with a 60 miles per hour direct crosswind, and I stoppeed and used a wind speed meter to check it, I had the Howard Steering turned on and at it's maximum 120 psi pressure setting. That much wind it could not compensate for, and every time we passeed a truck or were passed by one, there was a large directional excursion as the side wind changed quickly. It made me realize how nice the system was at all other times when it worked just fine. And made me feel sorry for those coaches that did not have it, especially the plastic ones.
When I get off the highway, I switch the system off to make maneuvering in parking lots, etc. easier. The wheel is a little easier to turn with Howard Steering off.
Jeff,
I had a driver's side front tire blow out on my 93 Newell on I 25 nearby the Santa Fe Skies RV park where POG 2 was held. I was on cruise control at 65 mph (my usual speed) when the tire blew. The coach tracked straight and I slowed down and pulled off onto the shoulder. No damage to the coach, but of course the tire was ruined. I was lucky; had I been on a curve or riding in the left (passing lane) lane I might not have been able to pull over quickly enough to slow down quickly.
Moral to this story is SLOW DOWN. If I would have been haulin' butt, I would have ruined my rim or worse. The difference between 65 and 75 is significant; 85+ is nuts! Slow down and enjoy the ride of your beautiful bus.
We like you Jeff and we want you to be around for a long time.:cool:
Tuga- Thanks again for yet another reminder. I've slowed down already. I didn't go very far today. I'm worried about the hot hub but I'm in the middle of the New Mexico dessert with nothing much around. I need to limp into Alb. NM to get the trailer looked after. I'm trying to find a place closer but there ain't much in these here parts.
There's a Stewart and Stevenson (S and S) in Albuquerque not far off of the Hwy. I-40 just east east of I-25 if you haven't found it already.
We are getting ready for another REALLY BIG SNOW!!:eek: :eek:
COBUS:
Speaking of Snow - My youngest is flying out to Denver Sat for Ski/Fun in the snow type deal/ for a few days. Is it a Blizzard Forecast again, is the all weather airport good to go or still full of stranded travelers?
I hope the dreaded thread police don't ticket me this time!
Hey Roger,
All the stranded christmas travelers are gone. The airlines are now cancelling some flights. The weather channel even has sent Jeff Bettis ( Abrams and Bettis show) here for coverage.Last week Jim Cantore was stranded in Crested Butte and couldn't cover our snow locally. Guess he skied instead.:D Haha, right now, all we have is rain. They say by rush hour we should have 5 inches, with another 9-18 over night. That is far as they can tell. One model of the clouds, they say will last until sunday. Another model says it will end tomorrow morning. So, as usual its a crap-shoot.
I have been trying to find a set of chain for the Airstream van since we are taking it to Rocky Mountain National Park for New Years. So far, no luck.
No luck means no go, its 2 wheel drive. They "SAY" there is another storm poised off the coast for mid week next week. Hope we can get out of here friday the 5th in the Coach for Palm Springs! I really don't want to chain up the bus.:eek:
Update 545pm mt time we have 6 inches of snow and they say it is coming down an inch a hour. Its a heavy wet spring like snow. Go figure. Friday, we should get the cold and wind, wonderful!
Jeff: I had a right side front blowout on my 93 40' xl two years ago. I was on i-95 south bound at about 68-70 mph. The first indication I had of the problem was a slight vibration of the rear view mirror. My first thought was a bad section of road as I knew my tires were new (less than 4000 miles) and I had checked the air pressure back at the Daytona track only 130 miles back. Before you could say Mango Kelly, the tire blew REALLY LOUD. I actually had no problem keeping it straight and eased off the throttle and slowed off on the shoulder. What I found when we got out was a couple of tire beads and a mangled coil of steel belts (from the guts of the tire). Luckily, the only damage to the bus was a section of foam insulation. Managed to change the tire in about an hour and continued South only to find not one, but two semi's less than a mile down both with flats! So, I feel it may have been some road debris, BUT, you never know. As for your hot wheel hub, check the wheel hub for oil NOW!!! If you have a leaking wheel seal, not only will you loose the brakes on that wheel, but you run the risk of heating up the wheel bearing so much that the bearing race can become welded to the spindle. I know....
For those that don't know, I didn't buy this trailer yet. I tried to buy it but someone in Georgia beat me to it so I'm using it from CA to FL in exchange for delivering the thing. I've been talking to guy about buying it from him for a profit but I've decided against it due to the weight primarily. 12,000 pounds empty before you even load the thing. That's just too much. The stainless is pretty and let's it match the coach but you pay the price for that both in the cost of the trailer and the weight. I spoke with a guy selling a Featherlite trailer and he said this brand of trailer (Competitive) is known for being plauged with axle issues from being too heavy. I guess even his double stacker Featherlite is still 10,000 pounds.
I'll look around for a non stacker that weighs 5,000 pounds or so if I still want a trailer by the time I get to FL. I did wind up weighing this thing and it is 17,000 pounds with one car. I thought about and decided that is too much weight.
Regarding the front tire blow outs, it sounds like the notion of using all your might to hold the wheel straight is a myth of sorts. I wonder why that guy told me his was harder to hold straight like that. I won't burden myself with worry over it anymore.
Jeff,
Phil Cooper just listed a stacker trailer.... maybe you could swap that one you have out. more info at: www.philcooper.com
I looked at it. $90,000 bucks for a USED stacker? :eek: That's insane. We sold a brand new one 2 years ago for $30,000.
$90,000 is off the wall for sure. Dumb. I understand that new tricked out Featherlites are $150,000 however. Dummer.
Even if you look at $50,000 for a trailer, check this out; you might as well buy a $30,000 plastic coach and tear it apart and make a trailer out of it with the spare $20,000 in modifications. Guess you would need a front engine in order to make this work and it might not actually be pracical but if you look at what you can buy for $50,000 and compare it to a trailer with no bathroom, generator, A/C , etc, etc, then it even compares out to look more expensive. Or start with a passenger bus for $10,000 and go from there modifying it. (nutty idea probabley). Then you have a trailer with it's own engine ! The downside is you need another driver of course.
I can't wait to get to Florida and take a bus break. Trailer ain't for me at present but if I do buy one I'll get something that weighs 5,000 lbs or less. 10,000 pounds with a payload is my comfort zone. When I was pulling this trailer empty it was 12,000 pounds and the feel of that was tollerable. At 17,000 pounds with one car it's too much for my taste. I'm waiting for something to break.
Well, I guess it is a little pricey, but hey... 3 axles and only 35 feet long - perfect for use in California. What do you suppose something like that scales out at empty?
I talked to a guy selling a Featherlite similar to this one and he said it weighs 10,000 pounds empty. Adding the stainless to make it match our coaches puts roughly 2,000 more pounds on it. That's too heavy either way for my tastes. I'll shop around for something about 5,000 pounds empty. If anyone see's one I might like I would appreciate the continued leads.
