Dear Abby-
It has seemed to me recently that my bus ride height is too low. It hasn't changed, I just started noticing other buses and a lot of them seem to ride higher. I'm CERTAIN that XL II's ride higher (mines a 95 chasis XL). Prevost confirmed that the XL II is indeed higher. I had Prevost check my ride height and they said it was good but I need to get a 2nd opinion. Can you measure from the bottom of a bay door to the ground and what is that supposed to be ?
Also, I finally got the bright idea to raise the coach an inch or two with the level low and just leave it there when I drive and I'm trying to experiment and get a sense if the ride is better or worse and it seems to me to ride a little bit better when I leave it up an little bit. Not too much, just a touch. I'm not hurting anything in my level low by doing this am I ?
