Quote:
Greg,
The decision about using city water (and pressures) or to pump from your holding tank is usually based on how your converter designed the water system. A conventional motorhome may have been equipped with a single low flow water pump so in that case municipal water would be the preference. But I think the Prevost converters today want to have a water system that is capable of handling multiple uses without any degradation in water flow so they are being equipped with high volume, high flow pumps so someone taking a shower is unaffected by someone flushing a toilet.
Mark is correct about not worrying about water pressure and I think you will agree the variations in municiple water systems will make it just nicer to use your pump.
