Batteries, Battery Balance, more.....
First, I have a Royal not a Liberty so I may be "interlopping" on the Liberty bunch here. I'm not certain if that is a POG no no but I'm new and randomly checking threads to see what I can learn and so far I'm learning a lot (I'm a first time motor home owner with 2.5 years into two different Prevost 1) Angola and 2) Royale. Have both still with the Angola in need of an engine that I'm shopping around for (any suggestions welcome. email me PLEASE).
Anyway, on the battery and voltage stuff, I seem to be getting poor performance on my house batteries even thought they are not that old and maybe I should be shutting off the 12 volt switch in the rear of the coach. I never turn this off when dry camping. Should I ? I'm not even certain if my house side still works or not or what this turns off. I didn't get an owners manual with my bus. Amazing what else I'm probabley ignorant of as well. I knew those switches were back there but I got the sense they were a security measure of something. Duh ? or is that correct somewhat also?
Regarding the fans running on the inverters, I understand that one of the posts was in reference (I think) to the ventilation fan but what about the fans that run on the inverters all the time by default? I have trace 2500's. (1997 Vintage). The inverters themselves are using power just being on in an "idle" so to speak are they not ? When dry camping, is it recommened to turn off the inverter all together ( the one that is not running the fridge) in order to conserve battery power ovenight ? I think I tried this once but haven't kept up the practice. I also THINK the "Search" mode on the inverter remote is supposed to turn the inverter off until such time when it is called on to invert. Comments ?
I'll hunt around the other sub headings and threads to see if there are some other posting regarding this or anyone that knows the site inside and out that wishes to point me in the right direction is welcomed advise also.
Dry Camping and Batteries
Number one; All Coaches are different but inverters and batteries are the same. Managing Inverters can be frustrating. As far as I know, the only way you can stop your batteries from dischargng when dry camping is to pull the wires off the batteries. Even if you turned the inverters off, the parasitic loads are still there. Depending on the percentage of charge your battery has, it will need re -charging within 8 hours by Generator, your engine, or shore power. The recommendation is to not let your batteries go down past 50 - 60 Percent before recharging. I had the Heart Inverter Rep change the readings on my previous coach displays to percentage readings instead of Amp Hours so I could monitor better the discharge rate. The Inverters ony shut down after they reach Float stage and that only happens when you are charging by Gen., Engine or Shore. Hope that helps.
