Replaced hydraulic solenoids..
I had my a problem with my slide outs today. I mention this because I know that there are a few POGGERS that are thinking about slides.
The bedroom slide would "stick" when the EXTEND button was depressed. The bottom of the slide room would run out before the top of the slide room. The top of the room seem to "stick". I called Newell service and they said that it was a faulty hydraulic solenoid. They recommended that I change both the lock & the unlock solenoids; the pins were not being retracted quickly enough to allow the room to glide out.
I changed the "lock" and the "unlock" solenoids. It took about an hour. Problem solved. Cost $190 per solenoid X 2 = $380 + $60 labor. Now both pins retract in time for the room to glide out evenly.:D :D
