Should I rotate my cars spare into tire rotation or not?
I would say use the ones most, whose filters are easiest to clean.
Further I would say that if you rotate the cruisair's use you will possibly wear them out all at the same time. Given the age of the owners in POG this could put their repair or replacement into a time when we would be too old to fix/replace them ourselves :eek:
It is better to use them individually and in the area that needs the cooling to best advantage and repair/replace them as the need comes up;)
If you turn your bus every couple years, then by all means rotate the use, that is, when it is warm in the front use the cruisair in the back and wear them out evenly and put the burden of replacing them onto the next/new owner.;)
:D
