http://im1.shutterfly.com/procserv/47b6d905b3127cce8b6d9565bf7300000010100EcM2TJwxZMX
Harry,
Some of us have no choice but to use the AGM's. My dual 4000 watt Trace Inverters have a software update that requires only AGM or Gel and the battery compartment has a placard warning of using anything else. The orginal Lifelines in the Bus (1997) lasted until Jan 2001. The group I just took out lasted 5 1/2 years and I think that's pretty good.
Anyone with a Marathon that's interested, here are a couple pictures of the finished product...
http://im1.shutterfly.com/procserv/4...100EcM2TJwxZMX
6 New 4D's and 2 New 27T for Generator
This is what the Equalizer looks like, ground must be removed prior to doing any work on the batteries. There is one up front for the house batteries and also one in the rear for the start batteries.
It's a big job, but the end result is knowing it's done right.;)
Premature alternature failure
I had the standard type altnerators going bad on my 94 Prevost also. I think these are rated at around 125 amps. I think mine went bad because my house batteries were hurting and that made the alternator work itself into the ground. I have a 97 coach now and when the same (stock) type of 12v alternator went out on it, I replaced it with a 270 amp Leese Neville brand alternator. It cost $1,300 but I think it will last and I get two beneifts from this more robost sollution.
First, I hate running my generator just to charge the house batteries. I move around more than average in my bus instead of sitting in an RV park for days and days so in my case, this alternator helps keep my house batteries up even if I only drive for a half hour or so. On a longer driver, it gives a real good deep charge as you would expect.
Second, I took all that extra available power and used it to run two of my roof A/C's while driving. Another thing I hated doing was having to run the Gen in order to A/C the rear if someone was in there while driving. For people with bus air this isn't an issue but I will never buy another bus with bus air. A waste of two storage bays in my opinion. So anyway, what I did was modify my two fuse boxes in order to let me toggle between shore / gen power and inverter power. I put another post about this somewhere else in the last week. I can tell someone how to do this or post a photo or something if anyone let's me know there interested. Your running the A/C's right through the inverters with this mod, not directly off the 12v alternator. So the alternator is just keeping up with the draw I'm putting on my house batteries. I never tried it with the smaller altnernator but this big one works great. I've heard that the newer coaches let you run one roof A/C but I wired mine for two and it's fine.
So that's how I justified spending the dough on the better altnernator. By the way, the new one had the exact same mounting pattern ad the old one. Save your receipt. It has a 1 year full replacment warranty.
I'd like to learn more about using the 6 volt batteries to solve house battery issues. I have not been happy wiht my house battery performance with either brand new Lifelines or Acid batteries which I have now. I figured for the price difference, I can afford to throw the regular batteries away every year for new ones for 4 years and be at the same investment as the Lifelines with the exception that you have to water them (that is a pain with my set up).
Jeff
Jeff
