dip switches (no not you!)
OK, I'm looking at my heart interface freedom 25 inverter/charger manual. A few questions.
1. I have two inverters... like everybody else I suppose. Do both inverters charge the batteries? Or is just one used to do that. I assume they are both set up for that.
2. I see that the dip switches can be set for different types of batteries. Wet cell cold, wet cell warm, gel cell cold, gel Cell warm. I have AGM, Lifeline 4D's. I assume mine should be set for one of the Gel settings. I have 8 options to choose from and it does tell me, for each battery type, the folloiwng specs:
what the Bulk Voltage/Max time is
the float voltage
and the Equalize Voltage.
I assume, somewhere, for Lifeline 4D's, there is a chart telling me what they should be set at, thus assisting me in choosing the setting?
Thanks!
Adam
