Ultrasonic & IR questions
I have seen a number of references to ultrasonic air leak detectors. Do they work and would anyone happen to have an idea as to what range of frequencies they are scanning?
Also, I have seen a number of dicussions of members using IR thermometers for checking the temp of their tires. So, if you have a hot tire, what are the things that cause it to heat up above normal? I understand friction from running low. Does a bad bearing, or other such problem in the wheel cause an increase in the temperature of the tire?
Captain Leak Detector and Trukster
Once upon a time I purchased a amplified microphone with a light on it from one Brian E. at a POG auction. I probably paid too much, but it was for a very worthwhile charity, and we were having a great time.
Well at the the mini POG/TGO rally, my close neighbor Pete Petree discovered he was losing air at his fan belt, but could not find the leaks' location.
With the handy dandy device in the hands of Captain Leak Detector (alias Toolman Jim Keller) and assisted by Truck and Pete, they quickly located the leak and With the turn of the wrench to tighten up an air line going to the regulator the leak was stopped - it was good to go.
Thanks to Brian E for donating it to the auction in Spearfish and we all enjoyed a few good laughs with the earphones on and fortunately did not damage anyones hearing, I think.
Attend a rally - who knows what you can find up for sale.
http://i52.photobucket.com/albums/g3...l/CIMG4367.jpg
