Frozen and left for dead @ Prevost Nashville
		I left my coach at Prevost Nashville in early November for maintenance work. I picked up the coach this Saturday. Needless to say I was surprised to find the coach water systems FROZEN and ALL batteries dead. They did have it plugged into shore power but failed to switch on the main breaker! (In the same bay as the glendinning in/out switch and not hidden) No one from Prevost works on Saturday's so there was no one there for assistance. I got lucky when the driver of an entertainer coach showed up (parked next to me) and he had TWO 20' jumper cables. After 1/2 hour we got it started. I let it warm up and turned on the Aquahot. In about 1 1/2 hours I was able to get water to trickel out of the sinks and found no leaks (to date) except for the toilet. The plastic valves broke. I ran the gen all the way home, and never shut down the engine. It's now stored in my heated warehouse now and I am keeping a close eye on leakage from the holding tanks. Can I assume that all batteries are shot or will they come back. What about future problems with any/all water systems/tanks. What would you do............?? BTW, George from Nashville did apologize.
		My .07 worth about Prevost & Buddy Gregg
		Well I would like to add my .07 cents worth to this Thread, about Prevost and one of the convertors I had to deal with at my last service.
My bus was at Prevost Ft. Worth for almost 7 weeks. What I had originally taken it in for, was to replace the roof in the slide with thicker ss. With this repair it was noted that I should also have stronger roof supports installed, I agreed and that was taken care of.  Then when Prevost began putting the salon slide back in, they noticed I needed the newer slide out pins and mechanisms, and asked if it would be alright to replace them, since the slide was already out?  I said sure go ahead and make it all correct and up to spec.
The three invoices that were sent to me for my records, totaled over $30,000:   The COST OUT OF MY POCKET   $  0  All of the Slide Roof work was covered under Prevost Warranty, at NO COST to me.  I am very happy about this outcome........
BUT several things on the inside of the bus during all of this work did get messed up, but not by Prevost, but by Buddy Gregg. Buddy Gregg was contracted to remove all furniture and fixtures in the slide.  When we picked up the bus the day before Christimas, we noticed these mistakes, and notified Prevost and Buddy Gregg, and Buddy Gregg is stepping up and taking care of these issues as we speak.
I am a Novice at all this bus stuff, and NO I can not stay with my bus each and every time something is worked on, I would like too, BUT I just can't.
BUT let me tell you, I have been very happy with Prevost Ft. Worth, and so far the work and effort put forth by Buddy Gregg in Lewisville, TX. too!
I will let you know if one of them does me wrong, WHEN and If the time comes.
I feel bad for the people that have things happen beyond their control to their beautiful buss, but somethings just are OUT OF EVERYONES CONTROL. !
Gary S.
