I bring this up here because I couldn't find any information on it.
Had to bypass the Liberty Watch Dog system to replace a fuel line and power wire to the generator fuel pump. I must have, though I don't remember doing so, flipped on what is labeled the "dog switch" (not the watch dog bypass switch) and that kept the Watch Dog system from allowing the generator to start from any remote switch. Turned the dog switch off and all is well.
This switch is in the first bay on the cabinet with the shore power breakers and the shore power selector switch. It is NOT described or illustrated in the Liberty manual.
The label says something like "Dog switch procedure: To arm, lift toggle switch up, shore power must be plugged in. If generator starts due to shore loss, correct and turn off dog switch and shut off generator."
Which means what ... if this switch is on when shore power is available, the generator will start if shore power is removed?
Maybe I just answered my question?
