For those of you that have never changed out an air governor, here are a few pictures:
Attachment 3184
Bendix Governor - 105 - 125 psi
Attachment 3187
To adjust your pressure, under the rubber cap is the adjusting screw
Attachment 3185
My governor is mounted to the rear of the air compressor
Attachment 3186
Installation complete
Some governors are remote mounted, but mine is directly bolted to the compressor. The governors are cheap, this rebuilt unit was 16.00. I got mine at Fleet, but most truckstops and parts places have them. There are different types and pressures, just make sure your part number is the same. I changed it as a PM item while chasing an aux air leak. This took about a half hour, mostly because you have to R & R your fittings as the governor does not come with fittings, only plugs that need installed in the unused ports.
Even Jeep could do this!:p
