Does Generator Charge Bus Batteries??
I am dry camping and have the 12/24 volt bus battery switches off. Prevost said to do this and it will not effect the Computer when turned off. I have no bus battery charger ( have ordered one that Mango recommended, arriving state side) and do not want to run the bus batteries down.
I start the genset twice a day, in the morning for a few hours and in the evening for a few hours, maybe a total of 4 hours. I leave the genset on auto start as well.
Question: When I am running the genset does it or would it charge the bus batteries at the same time if I had them turned on, or does it charge them anyway. I am thinking it does not, as it would create a problem when the bus engine is on running down the highway with the genset creating an overload unless it is smart enough to cut the circuit off during these times?
Burning empty jerk chicken boxes?
Tom, why don't you tell EVERYONE how you really feel about the state of Mango's gen? Great description!:D
Darl
Yes, you can do it with solar, but...
Bruce, I've been living very comfortably with my 1100 watts of solar and haven't needed to run my generator (other than to exercise it) since January. However, 14 solar panels (8x100 + 6x50) are hard to justify if you're not fulltiming. Also, dedicating that much roof space to solar may require the use of :eek: basement air. My 24 volt 3-stage solar charge controller usually has my 8 8D glassmats in float mode by 10am and has my starting batteries up as well. I don't have my big 24 cu ft Jenn Air fridge running on 24v. yet, but spreadsheet calculations show I should not be forced to run the generator below 90 F. Summertime highs are usually around 80 F here in Flagstaff. With no sun, my generator charges all batteries through the inverter/charger.
In full sun, I've seen 40 amps @ 24v coming down. That won't handle your 220v cooktop or A/C and you must minimize your phantom loads, but you can nuke lunch and supper and run the computer or TV all evening.
My $.02 worth.
