XL1 cracked Awning Upper Window
I have a large crack in my P/S second awning upper fixed window pane. Is Prevost the only source for this or can I go to a glass company for replacement?
Also how does the window come out, do I have to remove the entire upper and lower to replace the upper glass?
Any help would be appreciated. I was going to try and drill a small hole at one end to keep it from spreading and then epoxy the hole and crack to stop any further spreading, but the crack is about five inches from the base of the window frame, any thoughts on this as well.
thanks,
Bruce
