Originally Posted by
flyu2there
Joe,
Airplanes have been using nitrogen for years for three reasons. First, it's very dry, no moisture at all. Second, the molecules of nitrogen are much bigger than oxygen, although I will yield that you only have 25 to 30% oxygen in your typical outside air, it leaks out slower and all tires do leak. Third, oxygen does not do well with heat...it gets hot and stays hot, the molecules get hot and start moving like Banshees and the pressure goes up......nitrogen on the other hand gets hot but cools quickly. Yes the pressure will go up but not nearly to the degree as standard outside air. While nitrogen is not one of the inert gases it can be stated that it's behaviour is inert.
I will yield to fact that nitrogen probably is not required in most typical operatios, especially with these busses however the evidence is out there that nitrogen is a far better medium. My personal reason for supporting nitrogen has to do with road heat. It is not uncommon for the roads and highways in the Desert Southwest to reach 130 degrees or more. I cannot tell you how many truck/trailer recaps are spread over the highways and byways of the Desert...they get hot and fail although we all know that most truckers use the low speed rated tires and usually re-cap as well...cheaper. Nitrogen, while it does not run any cooler, at the end of the day it will take longer to heat up will dissapate the heat much faster and that's enough for me.
I guess we can agree to disagree....:D
John
