It just gets funner and funner
Mango,
Attacked the Webasto...mine is a DBW 2010 and instead of 3, 13 mm whatchamakaulitz there are two, at 4 and 7 o'clock and they are 10mm....yep you need a 10" extension. Pulled it all apart, pulled out tested and cleaned photocell..ok. Pulled the injector, dumped it in carb cleaner and blew it all out. Spent a good 45 minutes trying to use that halffast feeler gauge they supply, to align the ignitors. Cleaned them up as well, ran a little 600 on them for good luck; no cracks or apparent damage, book says they are o.k. Put it all back together, had to pull that monster cotter pin to do it, and fired it up....NUTTIN.
Went into the voltage department and all of that checked ok. Used the checklist and everything pointed to the motor. Pulled that black plastic cover, exposed a clock motor. Turned fine, pulled it, put it on 12V, 1 amp and it spun like a top. Put that whole mess back together, that clutching system looks like a tinkertoy, sprayed it with silicone and slapped it back together again.
Country Coach has that Webasto as far back on the RH side as they can get it, end result is that my hands look like I pulled apart two fighting male cats. Also, I didn't like the looks of some of the fuel lines so I am going to change them now....then a Jack Daniels.
I will try again tomorrow to fire it off.......looks like a whole lot of aggrevation could be avoided with the Webasto handy-dandy testor.
John:eek:
