Washed the Bus today, 54 degrees out after three days below freezing, kinda normal. Untill I got inside the coach to move it back inside the basement. I have an alarm going off inside that I have never heard before. The alarm speaker is small about the size of a half dollar and about 1 inch tall. It is screwed to the steel frame work of the passenger side lower dash in behind everything imaginable. It is near the module for the keyless entry, to the right of the windshield wiper motor, and behind the defrost and heat ducts. Cannot see it but can feel it. In addition, I killed all power to the coach and it continued to beep. It is faint and sounds like it has a weak battery for its own power source.
Not the burglar alarm, not the fresh or waste water tank alarm, not the alarm clock, not the keyless entry module -
Anybody got an idea what its for and what does it mean when it goes off???I have had the coach for more than two years and have driven it 50k miles and this is my first experience with this. I wondered at first if it was an air strike but no way now after finding the culprit.
