Voltage, well regulated, please...
I have noticed that when I start up the bus and let it run, I am seeing in excess of 15 volts on the gauges, both house and chassis batteries.
Additionally, my inverters shut off and the display for each indicates over-charging of the batteries.
So, am I correct in thinking that the voltage regulator needs replacement or simply adjustment?
And, if adjusting the regulator is the answer, how would it have gotten "out" of adjustment, or does this indicate that something is going on with the alternator?
We may be on to something
I am back at my office for a while but I stopped at home for a bit when I came back from the Dr. I removed the cover on the rear circuit breaker and with some limited testing found that I only have 12V back there including the 24V switch. I tried CB6 and had nothing. Tried with both master switches on and off. Still nothing. This may be just as you all suspected from the start, a circuit breaker. Now, my questions are; if this has indeed failed (I will double check it in the morning) should I replace it with a 105amp and where do they sell this type of breaker? Smith Power Products, Detroit Diesel does the service on my Prevost but they order the CBs from Prevost.
Again,everyone, thanks for all your help. I hope to return the favor one day soon!
