Good afternoon,
Since purchasing coach (November 06) the gen set runs hot. It will get to 225 degrees when under load. The radiator is far away in the front of the coach. I have bled the line of air multiple times. The line to radiator is at 225 degrees, the line from radiator is at 185 degrees. These are measured by infrared thermometer. The radiator is putting out hot air. Everyone seems to want the gen set not to run over 200 degrees. The thermostat is working else there would be no flow to the radiator (at least that is what I think is correct).
There is fan behind radiator (the radiator lies down flat in front storage area of bus). the fan is working since fairly high volume of hot air leaving radiator.
Amount of antifreeze is correct. Mixture is correct. Any suggestions?
thank you
Kim sloan
02 Vantare XLII S2 (yes it is fixed see separate post)
06 dodge megacab
