I guess you must attack what you don't understand did I spell that right ?
To answer some of your wonderful comments
This coach will have over 600 horse power in it .
The shell is 20 yrs old but I stripped it down to just its bare frame and every nut and bolt and wire and all the sheet metal is brand new . And yes I plan on buying every H560 in the Us and in Canada . The camp ground thing , this coach is not meant to go into little mom an pop rv camp sites . But if you can get your 45 ft. coach in one I could get this coach into it as long as the site was 80 ft. long . As I explained this coach can turn on its set back second front axle it will make a lot tighter turn then any 45 ft. coach out there will, and with its motorized leveling legs I can move the front or rear section side ways together or one at a time.
This type of coach does not fall under the same guide lines as a regular coach does for highway use. And I have drove tractor trailers most of my life and I am used to driving really big things around so I know this kind of coach is not for every one . But you would have to drive it before you could really under stand how easy it is to drive it and move around with it. Being able to turn on the set back front axle, it bends in the middle and the rear axle turns as well with the motorized leveling legs you would be amazed at what you can do with this coach . You also must under stand the front section is shorter the 45 ft. The front section of this coach is only 35 ft. long. And as long as you can get the front section around a corner the rear just fallows . Well that’s all the time I have for to day . But keep those kind questions coming and I will try my best to answer them all as soon as I figure out how to spell and write . Thank you Dave
