PM item on Generator to keep in mind
My wife smelled something electrical burning the other day. I pulled over promptly. Checked the computer printer, ok. Chekced the battery bay where the inverters were. Ok.
Found a few days later that it was in the control box for the generator. Bad ground wires the tech suspected. No parts damaged, not even the regulator and it was just a matter of trimming back the burned wires and cleaning up the connections. This is not the transfer switch, this is a box that sits with the generator set and where the rubber meets the road for throwing the power out into the coach and into the inverters and so forth.
FYI for anyone out there with older coaches to consider this a Preventative Maintainence item. My coach is 10 years old. I've had a few close calls with generator fires including the fire supresion system I had installed blowing up instead of acting as a safety device.
The tinkering and mechanical stuff just never ends I guess.
In New York for about a week now and only got 1 $40 parking ticket in Long Island. Found a driver with a movie pass that is good through 7/2002 so if anyone else wants to come park in NYC I can scan it and you can print it and tape it to your window.
The Last Place You Look ?
WHY do you always find things, THE LAST PLACE YOU LOOK ? :confused: :eek:
