Webasto Operating Question - CC XL
11/4
Hi to Country Coach XL owners. I found very little in the publications with my coach about the Webasto. Getting into the 20's a week ago was a wake-up call. The new DuoTherms worked well on the heat pump cycle and brought it up from the 40's to 70 in no time. I have the Webasto system. Checked threads I could find. Seems as though some work from the thermostat; others have on or two separate just for the Webasto. I do not see separate controls. I do have Webasto/Heat button/switches overhead in the cockpit. Do I just fire up and off as needed? I do not see any temp adjust panels...... Thank you if you can help.
Sincerely,
Doug
Nash XL
1999 Country Coach
