I need to replace my house batteries. Batteries Plus sells AMG 8D's for $550.00 each. Does anyone know if/where I can buy them cheaper?? Also, AMG vs. Gel??
Thanks
Thanks
BL,
I replaced the AGM's in my Liberty, also from Battery Plus for about that amount. I believe AGMs are the only way to go.
Here's some info:
"Gel Cells use a thickening agent like fumed silica to immobilize the electrolyte. Thus, if the battery container cracks or is breached, the cell will continue to function. Furthermore, the thickening agent prevents stratification by preventing the movement of electrolyte.
As Gel cells are sealed and cannot be re-filled with electrolyte, controlling the rate of charge is very important or the battery will be ruined in short order. Furthermore, gel cells use slightly lower charging voltages than flooded cells and thus the set-points for charging equipment have to be adjusted.
Absorbed Glass Mat (AGM) batteries are the latest step in the evolution of lead-acid batteries. Instead of using a gel, an AGM uses a fiberglass like separator to hold the electrolyte in place. The physical bond between the separator fibers, the lead plates, and the container make AGMs spill-proof and the most vibration and impact resistant lead-acid batteries available today. Even better, AGMs use almost the same voltage set-points as flooded cells and thus can be used as drop-in replacements for flooded cells.
Basically, an AGM can do anything a Gel-cell can, only better. However, since they are also sealed, charging has to be controlled carefully or they too can be ruined in short order."
Additional Information here:
http://www.vonwentzel.net/Battery/01.Type/index.html
MIke
http://www.eastpenn-deka.com/default.aspx?pageid=843
look for your closest location, place in Nashville is great, they will even install them for you.
Are yours 8d or 4d size? I was talking to Lifeline (Justin) owners son about the POG discount, he said that 529 or 497 delievered to the rally site. I said I would get back to him if there would be interest.
http://www.lifelinebatteries.com/rvbatteries.php
Mine are 8D & I need 5. I will not be attending POG IV. Batteries Plus does distribute the LifeLine brand and I'll stop in and ask for a discount on 5. We'll see. PS These things are heavy, like 150-160 lbs. When I tried to lift one my feet come off the ground!
I replaced my house batteries last March with AGM batteries from MK.
http://www.mkbattery.com/
They were roughly 1/2 the cost of lifeline (I don't have absolute figures available right now), but I put in 4D's for somethere in the low $225 range?
They are working great.
I want to echo what Mike posted. For anyone considering batteries the rage in the early 90's was gel cell and it was frustrating for some.
The environment the batteries are placed in is important in the selection process. If the batteries are in an area where heat is generated, such as near the engine do not use Gel cell because they cannot handle the heat. They will literally explode. For areas such as that flooded cell are best, which is why the coach batteries are likely to be maintenance free flooded cell batteries such as Delco 1150.
Where heat is not an issue AGM or Gel will work, but no matter what is installed the inverters or chargers must be set to the charging protocol. On our inverters, and I assume all inverters there are ways to set the inverter to the charging cycle required by the battery and to limit the voltages as well. AGM for example cannot be charged at the more common voltage of 14.2.
When changing batteries it is important to consider all the necessary conditions.
Ray, I am going to change my batteries this winter and have a MK outlet close to me in Florida. I haven't received a price as of yet. As soon as I get back to Fl. I'll start working on that.
Did you check out all of the other specs and compare them to Lifeline? My coach takes 4D size also and I need 6.
Lew
Mango: Boy am I impressed, I thought Jerk Chicken was your speciality and founding member of the TBC.
Great info, your a real asset to the forum, no matter what JDUB, A1, Truck and Loc and all the others say about you.:cool:
Fast Roger,
Don't be too impressed as it's information I tracked down on the internet. The only reason I had even an inkling as I had to spend some Lewbucks on the Mothership's batteries and tried to do my homework prior to purchase.
Now, as Tom is found of saying, back to Jerking my Chicken.
Mike
